Autor Tópico: NISSAN - Langley (N12)  (Lida 3767 vezes)
Offline blardY
  • Moderador Global
  • Liked: 1
« em: 14 de Janeiro de 2007, 05:36 »
Este fabuloso motor (E15) era usado não só nos ET´s como nos EXA, neste tópico falemos de ET´s
Engine Info
Body
Four-door Hatchback
Drive Transverse front engine, front-wheel drive, five-speed manual trans
Engine E15 1488cc, in line four, ohc, 8V, efi, Garrett T2 turbocharger (water-cooled on unleaded), 7.4:1, 7psi, non-intercooled, Bore x stroke: 76/82
Power/Torque 77kW@5600rpm157/Nm@3200rpm, 6000rpm redline (leaded)
74kW@5600rpm154/Nm@3200rpm, 6000rpm redline (unleaded)
How heavy 938 kg
Suspension Front: Independent by MacPherson struts, coil springs/telescopic damper, transverse link arms, anti-sway bar
Rear: Independent by trailing arm, coil springs/telescopic dampers, anti-sway bar.
Length/Width/Height/Wheelbase 3960/1620/1390/2415mm
Wheels & Tyres 14 x 5 inch alloys and175/65 tyres
Brakes Solid discs; front (240mm) and back
Performance 0-100kph/0-400m 9. 2 sec/16.5 sec (leaded)
9.6 sec/16.7 sec (unleaded)  Top speed:177kph.
Há várias versões do modelo:
Aqui fica também uma foto com um EXA (lado direito).
Edited by: Umtali at: 7/10/07 17:41
Offline blardY
  • Moderador Global
  • Liked: 1
Re: Nissan Langley (N12)
« Responder #1 em: 15 de Janeiro de 2007, 03:18 »
www.n12turbo.com/
Edited by: Umtali at: 30/9/07 23:27
