This was Japan’s first Formula 1 car, and was created by Honda based on motorcycle technology. The laterally mounted V12 engine produced 220 ps/12,000 rpm, and the rear featured 4 exhaust pipes that each served 3 cylinders. The body was also a Honda-designed original, but it exceeded the minimum weight requirement by 75 kg as it had to support an engine weight of 209 kg.
Storage location : HONDA COLLECTION HALL (Twin Ring Motegi, 120-1, Hiyama, Motegi-machi, Haga-gun, Tochigi-ken 321-3597)
Year manufactured : 1964
Manufacturer : Honda Motor Co., Ltd.
Classification : Other
Current status : On public display: static
Vehicle name / Manufacture
Vehicle name : Honda RA271
Company name : Honda Motor Co., Ltd.
Vehicle type/usage : Racing car
Location of actual vehicle/replica : Honda Collection Hall
Model / Weight
Passenger capacity : 1
Vehicle weight : 525 kg
Body / Size
Structure : Alloy monocoque + subframe
Tire size : 600L-13 700L-13
Body / Axle / Driving / Others
Frame : Monocoque + tubular subframe
Wheelbase : 2300 mm
Front tread x rear tread : 1300×1350 mm
Steering : Round steering wheel
Stabilizer : Torsion bar
Engine / Size / Power
Cooling/cylinder arrangement : Water-cooled/V2
Valve train : DOHC, intake: 2; Exhaust: 2
Bore x stroke : 58.1×47.0 mm
Displacement : 1495 cc
Max. power/r.p.m. : Over 220/12000
Hybrid
Hybrid system type : None
Drive-train
Transmission : 6-speed
Drive system : Mid
Video!!!
Nelson (kombota)
